1994 Cadillac SLS Engine will not crank over
115,620 MILES • V8 • FWD • AUTOMATIC
ROBERT DEANGELO
need to know what i need to remove to replace ignition starter or is it a badd relay or bad fuse? thank you bob!
Feb 26, 2010 at 10:10 AM
FACTORYJACK
  • 4,159 POSTS
If it is not cranking, has the battery connections and battery itself been checked? There is a connector at the front of the rear bank cam cover that has the starter signal wire. You can disconnect and feed power on the starter side of the purple wire to see if the starter engages. If it does, check the harness side with a test light to ground, when ignition is in crank to see if there is a signal on that wire.
Feb 26, 2010 at 6:26 PM
