no start
PARTSGAME
92 cadillac seville 4.9 150,000 miles. No start. Will start with screewdriver across soleniod. Run for minute then stall. Start at lock cyl and no crank
Aug 20, 2007 at 9:17 AM
  • 75,988 POSTS
[quote:341e7f6686="partsgame"]92 cadillac seville 4.9 150,000 miles. No start. Will start with screewdriver across soleniod. Run for minute then stall. Start at lock cyl and no crank[/quote:341e7f6686]
Run for minute then stall. when doing this with the screwdriver do you just tap it or constantly connecting it and at the same time hearing the starter cranking the engine or whatever.
Or just tap on it and runs for a min.
Disable the ignition put key in start postion at the solenoid little wire does it have power?
Aug 20, 2007 at 1:41 PM
PARTSGAME
no start started after tapping soleniod. ran for a second then stalled. no power to soleniod.
Aug 21, 2007 at 8:49 AM
