2002 cadillac seville sls
DJMONTES
Hi, I own a 2002 Cadillac Seville SLS 4.6, bought it on 36000 miles it has 46000 actual miles in 9 months. I've been checking the oil level periodically (weekly) and it seem to need at least half a quarter to a quarter of oil every other week. driving on normal conditions. I don't see any leaks and no smoke any color coming out of the exhaust. The car runs great, a friend told me it could be the head seals but i don't see any oil on the engine either. I don't know what else to do.
Nov 29, 2006 at 7:30 AM
GWH
  • 14 POSTS
[quote:5a130e8a66="djmontes"]Hi, I own a 2002 Cadillac Seville SLS 4.6, bought it on 36000 miles it has 46000 actual miles in 9 months. I've been checking the oil level periodically (weekly) and it seem to need at least half a quarter to a quarter of oil every other week. driving on normal conditions. I don't see any leaks and no smoke any color coming out of the exhaust. The car runs great, a friend told me it could be the head seals but i don't see any oil on the engine either. I don't know what else to do.[/quote:5a130e8a66]
This is normal for the Northstar engine to use some oil. I've had two Caddys with the Northstar engine and both used about 1 to 2 quarts of oil between changes.
GWH
Aug 12, 2007 at 11:34 AM
THUNDER
  • 72 POSTS
If you don't mind Jiffy lube, you get a free top-off on ALL fluids. Not bad for a $30 oil change.
Nov 27, 2007 at 3:59 AM
BUZZSAW
  • 1,198 POSTS
[quote:c941009a21="djmontes"]Hi, I own a 2002 Cadillac Seville SLS 4.6, bought it on 36000 miles it has 46000 actual miles in 9 months. I've been checking the oil level periodically (weekly) and it seem to need at least half a quarter to a quarter of oil every other week. driving on normal conditions. I don't see any leaks and no smoke any color coming out of the exhaust. The car runs great, a friend told me it could be the head seals but i don't see any oil on the engine either. I don't know what else to do.[/quote:c941009a21]
you need to do a top engine clean and free up the piston rings, cadillac says 1 qt per oil change is normal, you do this by warming up the motor and putting top engine cleaner in the spark plug holes, let it sit for 24 hrs and change oil, may have to repeat couple times
Nov 30, 2007 at 1:44 AM
