2002 Cadillac Seville ABS Codes
113,000 MILES • V8 • FWD • AUTOMATIC
BJ58348
My Cad is showing the traction control light and the cruise control is not working. I pulled the codes and they are: ABS ID 2230
ABS C 1294
MSM B 1850
PCM P 1574
On occassion the check electrical system words come up as well. I've checked the battery conections as well as the condition of the battery and charging circuit. I also pulled the front wheels and checked to see if the sensors were conected properly and clean. Where do I go from here?
Thank you for your advise.
Sep 7, 2010 at 8:19 AM
FACTORYJACK
  • 4,159 POSTS
Check you brake lamps, more than likely the right and left bulbs are out. The high mount should work indicating that the switch works. This era of seville sets a stoplamp switch fault when the brake lamp bulbs fail, and often times the switch gets replaced when it just needed bulbs.
Sep 8, 2010 at 3:34 AM
