2002 Cadillac Seville ABS & TC light comes on occasiona
BGHASSEMLOU
  • 8 POSTS
Brakes problem
2002 Cadillac Seville V8 Front Wheel Drive Automatic 110K miles
ABS & TC lights comes on only after we go over a bump or pothole. Sometime “Service Stability” warning also come on.
When ABS & TC lights are on ABS will not work.(i.e. is slides on snow without control)
My mechanic did not have diagnostic reader for ABS. I had Cadillac dealer get the codes, here they are:
History codes are C1223 C1224 C1228 C1235 C1248 C1254 But not present!
(i.e. when Switch off-on will reset ok)
C1223 - Left Rear Wheel Speed Sensor Input Signal is 0.
C1224 - Right Rear Wheel Speed Sensor Input Signal is 0.
C1228 - Right Rear Excessive Wheel Speed Variation.
C1235 - Right Rear Wheel Speed Circuit Open or Shorted.
C1248 - EBCM Turned the Red Brake Warning Indicator On.
C1254 - Abnormal Shutdown Detected.
Could you suggest what could be the problem. Thank you.
May 27, 2010 at 2:54 AM
FACTORYJACK
  • 4,159 POSTS
Initially, what I would do is clear the codes, and drive until the warning indicator returns. See which codes(s) return. This will give a more definate indication of who is causing the fault. You will not need to return to dealer for diagnostics, your vehicle has an onboard feature that will display codes. To enter that onboard feature, push and hold the info up, and on/off button simultaneously, until the segments illuminate. You info center on the cluster should read ALL?. From here you can use the info button to scroll modules alphabetically, up or down. Roll to ABS?, and press on/off. It should change to ABS CODES?, if you use the info button at this point it will toggle between that, and ABS CLEAR CODES? Like I said previously, clear them first, you can do this by pressing on/off. It will acknowledge by displaying ABS CODES CLEAR. Drive until warning indicators or message appears, and run this process again, only pressing on/off after the display reads ABS CODES?. Report back.
May 27, 2010 at 2:11 PM
BGHASSEMLOU
  • 8 POSTS
Thanks for instructions.
We cleared the codes. Road test the lights came back on. stopped the car and read the codes again:
C 1235 History. Cleared the code and repeated. road test:
TC & ABS lights on also Service Stability System Warn. came on:
Checked the codes while car was running:
C-1235 History
C-1228 Current
Thank you again for any recommendations
P.S.
only C-1235 History is persistent after clearing again
May 28, 2010 at 2:40 AM
FACTORYJACK
  • 4,159 POSTS
That narrows it down to the right rear circuit. At this point, and the fact that it is intermittent, a few things are possible. The only situation may be when it is stationary, the fault does not occur. It is possible that you have a faulty rear wheel speed sensor(hub/bearing), terminals in the sensor connector(harness side) that have lost some tension/poor fitting, or wiring issues from the RR wheel sensor to the EBCM. There is one way of isolating the sensor, but it requires a bit of work. The right and left wheel hubs could be swapped(in contrast to just replacing the rh side). If you roadtested it afterward and your codes followed the sensor, then replace the hub. Looking at the terminals, it is not real obvious if they are lacking tension. Usually in the field, we use a male of the same type(in this case metri-pack 150 male), insert it into each female terminal, and if you invert it and the male falls out, it is loose. If you pick the rear wheels up off the ground, there should be no play when grasped at 12 and 6 and wobbled. I would proceed with either replacing or swapping the rear hub(your choice), if it doesn't change check the terminals, and if you still find nothing you are going to need to check wiring. That is where it may get a little complex.
May 28, 2010 at 4:03 PM
