2001 Cadillac Seville stabilty system
2001 CADILLAC SEVILLE
103,350 MILES • V8 • FWD • AUTOMATIC
GEORGE748
My car occasionally displays "service stability system", I have been told that this is basically some sensors,however from time to time I can feel a mechanical engagement and the info center then says" stability system engaged'. What is this and what can I check to see why it does it for no reason at all.
Jun 4, 2008 at 2:58 PM
BUZZSAW
  • 1,198 POSTS
[quote:07434b93a6="george748"]Drive Train Axles Bearings problem
2001 Cadillac Seville V8 Front Wheel Drive Automatic 103350 miles
My car occasionally displays "service stability system", I have been told that this is basically some sensors,however from time to time I can feel a mechanical engagement and the info center then says" stability system engaged'. What is this and what can I check to see why it does it for no reason at all.[/quote:07434b93a6]
scan your codes, off and down on the mode button at the same time, with your key in the on position
Jun 8, 2008 at 9:02 PM
