2001 Cadillac Seville change brake pads sensor
2001 CADILLAC SEVILLE
DLT56
Brakes problem
2001 Cadillac Seville V8 Front Wheel Drive Automatic
I recently changed brakes and the change brake pads message is still on. How doI reset that?
Apr 6, 2009 at 4:13 AM
FACTORYJACK
  • 4,159 POSTS
Did you replace the sensors, they are on both front and rear.
Apr 6, 2009 at 4:52 PM
DLT56
No I did'nt replace the sensors.
Apr 12, 2009 at 4:42 AM
FACTORYJACK
  • 4,159 POSTS
If they were down to 1mm or so, the sensor has worn through. Was it a change brake pads message that prompted you to replace in the first place? If so, you need to replace sensors on that axle. Inspect your brakes all four, and see if any of the sensors are contacting, disconnected, or have damaged wiring due to road debris/chains, or improper routing.
Apr 13, 2009 at 5:43 PM
