2001 Cadillac Seville ac not blowing in the front
2001 CADILLAC SEVILLE
114,000 MILES • V8 • 2WD • AUTOMATIC
JLAMB
ac does not blow in front or turn on.. back ac vent blow when they are turned on.. could it be just a fuse or do i have a bigger problem on my hands
Feb 8, 2010 at 3:16 AM
FACTORYJACK
  • 4,159 POSTS
You do not have a fan for the front, no heat, defrost, or any air movement. The first thing to check, and it will determine if you need to go any further, is power and ground at the blower motor with system on. This can be done with a test light across the blower motor connector.
Feb 8, 2010 at 1:14 PM
