2000 Cadillac Seville firing order
86,000 MILES • V8 • FWD • AUTOMATIC
GLENNDEE
what is the correct firing order for this engine??
Apr 3, 2008 at 12:51 AM
BUZZSAW
  • 1,198 POSTS
[quote:877c23ffac="glenndee"]Electrical problem
2000 Cadillac Seville V8 Front Wheel Drive Automatic 86000 miles
what is the correct firing order for this engine??[/quote:877c23ffac]
that motor has coil packs doesnt it? in the top of the heads, or does it have wires?
what do you need it for?
Apr 3, 2008 at 8:21 PM
GLENNDEE
yes it has coil packs not wires, the check engine light is on and when checked it says misfire on number 6, which cylinder is no 6??
Apr 4, 2008 at 12:25 AM
BUZZSAW
  • 1,198 POSTS
[quote:80a4436866="glenndee"]yes it has coil packs not wires, the check engine light is on and when checked it says misfire on number 6, which cylinder is no 6??[/quote:80a4436866]
the back head is the even cylinders. 2 4 6 8 third 1 back from the frt of engine
also if you want to ck the spark plug, be careful removin the coil pack and spark plug boot the boots tear easiely
Apr 4, 2008 at 7:21 AM
