1999 Cadillac Seville where is the termostat for this vech
1999 CADILLAC SEVILLE
86,000 MILES • V8 • 2WD • AUTOMATIC
BABYBOY27
haveing trouble locating the termostat on this vech
Mar 21, 2009 at 5:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Follow upper radiator hose to engine. Thermostat housing is inside of radiator hose where it connects to engine.
Do the following to remove:
Disconnect the negative battery cable.
Drain the coolant.
Remove the air intake duct.
Disconnect the radiator hose
Remove the thermostat housing.
Remove the thermostat.
Thanks for using 2CarPros.com!
Mar 21, 2009 at 8:18 AM
