Follow upper radiator hose to engine. Thermostat housing is inside of radiator hose where it connects to engine.
Do the following to remove:
Disconnect the negative battery cable.
Drain the coolant.
Remove the air intake duct.
Disconnect the radiator hose
Remove the thermostat housing.
Remove the thermostat.
Thanks for using 2CarPros.com!
Mar 21, 2009 at 8:18 AM
