the blower stays on when the car is turned off. is this a relay switch gone bad or some thing else?
Feb 2, 2009 at 1:41 PM
DOCFIXIT
✓ASE Certified Mechanic
Faulty Blower Control Module located under right dash near center vents.
Feb 3, 2009 at 9:55 AM
DROSSART
MEMBER
I have recently subscibed to the on line repair manual. In my last question about the blower motor, it was supposed to be for a 1999 deville NOT seville, my bad. In the manual, I have found a blower motor resistor mod. (rear). I don't think it describes the same blower (I could be wrong). Please advise.
Feb 16, 2009 at 1:04 PM
DOCFIXIT
Then heater A/C programer module rigt side behind glove box. But need to know Auto A/C dual cl9imate control OR manual heat A;/C?
Feb 17, 2009 at 9:07 AM
DROSSART
MEMBER
not duel control
Feb 17, 2009 at 11:05 AM
DOCFIXIT
Is it auto temp control? A LED panel on cotroler?
Feb 17, 2009 at 11:13 AM
DROSSART
MEMBER
auto temp/LED
Feb 17, 2009 at 11:48 AM
DOCFIXIT
Then it is the heater A/C contorl module right side dash behind glove box. Motor is wired hot all the time it is grounded through pragramer module.
Feb 17, 2009 at 1:28 PM
