1999 Cadillac Seville
MROTNEZ
Electrical problem
1999 Cadillac Seville Automatic
what does service system stability mean on a 1999 Cadillac Seville SLS
Mar 16, 2010 at 5:38 PM
FACTORYJACK
  • 4,159 POSTS
You have a fault in your VSES system, otherwise known as ABS/Traction control. It would store a code. If you press info up, and on/off, it will enter diagnostics. After a segment check it will display ALL? From there the info button up, or down, will scroll modules alphabetically. Locate ABS?, then press on/off. It will either display ABS codes?, or ABS clear codes?. Locate ABS codes, and press on/off. Record the code(s), and report them to me, I will assist you as much as possible.
Mar 17, 2010 at 4:35 PM
