1998 Cadillac Seville Overheating
1998 CADILLAC SEVILLE
102,700 MILES • V8 • 2WD • AUTOMATIC
SWELLA
I've had 2 new thermostats, a water pump, radiator cap, new wiring and plugs installed. The coolant level goes low every 3 or 4 days and I have to refill it or the engine will run hot. Help!
Nov 7, 2008 at 1:22 PM
BLUEMAN
you left it a little open ended do you see it leaking at all. if not the engine is probably burning it up some were so there might be a crack in the intake or a blown head gasket you need to give more info
Nov 7, 2008 at 1:48 PM
