1998 Cadillac Seville no spedo check engine and hard shifti
PAUL LANNON
Transmission problem
1998 Cadillac Seville V8 Four Wheel Drive Automatic 98k miles
Hello i have 1998 sls with the northstar
My problem is this my spedo stopped working from time to time then the check engine lite came on and the the transmission would not shift out of 1st in less i gassed it up to 4k rpm them it shifted normal but still no speedo and im getting lousy fuel milage, can you enlighten me on the problem before i spend my kids college money on repairs i dont need, is it a sensor or is it major. I disconnected the battrie and it still did the same......
i went to auto zone and they told me it was the speed sensor also, however they had 2 different ones. my question is this does the speed sensor go from the throttle body to the tranny? if so is it a hard fix
May 13, 2008 at 7:12 AM
BLACKOP555
  • 10,386 POSTS
if i was to take a jab at it i would guess a vehicle speed sensor problem.
buzzsaw will post back probably and tell you how to retrieve the codes from your caddy.
May 13, 2008 at 9:05 AM
BUZZSAW
  • 1,198 POSTS
[quote:5dbc413d18="blackop555"]if i was to take a jab at it i would guess a vehicle speed sensor problem.
buzzsaw will post back probably and tell you how to retrieve the codes from your caddy.[/quote:5dbc413d18]
thank black,,, do off and warmer on your heater controls at the same time, with your key in the on position. write them down and post them here!!!
the speed sensor is inside the trans, the trans will have to come out to repair, there are two other sensors in there and a wiring harness that should also be replaced
pull the codes first and lets see
May 14, 2008 at 5:56 PM
PAUL LANNON
The code that auto zone game me is P052
So you are saying the transmission has to come out to replace this ouch ouch.....
May 15, 2008 at 6:05 AM
BUZZSAW
  • 1,198 POSTS
[quote:85f9296810="paul lannon"]The code that auto zone game me is P052
So you are saying the transmission has to come out to replace this ouch ouch.....[/quote:85f9296810]
scan your codes, off and warmer on the heater controls at the same time, with your key in the on position. this will scan your codes, look in the message center for them, I need history and current ones, write them down
May 15, 2008 at 7:56 AM
