1997 Cadillac Seville Trouble Code
72,897 MILES • V8 • FWD • AUTOMATIC
BIZ08726
I have a trouble code of P0741. I also have limited financial resources to spend on fixing this car. Please can you tell me what part I will need to fix this trouible, so I can know if I can offord it before I take it to a dealer.
The trouble code is P0741 and I was told that this means that TCC Circuit is perfectly stuck, whatever that means.
Can you help me?
Jan 25, 2008 at 1:30 AM
MASTERTECHTIM
  • 4,750 POSTS
sounds like your torque coveter clutch solenoid is no good. how does your car drive? are you fixing this just because the light is on or because transmission is acting up?
Jan 25, 2008 at 1:51 AM
BUZZSAW
  • 1,198 POSTS
[quote:0660f8010f="biz08726"]Electrical problem
1997 Cadillac Seville V8 Front Wheel Drive Automatic 72897 miles
Can you help me?[/quote:0660f8010f]
yes thats a torque converter code but there could be other problems and it can cost plenty, the trans has to come out to ck it, if no problems found a basic cost would be 6-9 hrs for removal and repair, parts all solinoids and a input speed sensor and the wiring to them, plus a couple gaskets, worse case, the input shaft wabbles out the pump and case, causing the solinoids to fail, a new trany
Jan 25, 2008 at 8:34 AM
