1997 Cadillac Seville Strange A/C Problem with 97 Seville!
12,700 MILES • V8 • 2WD • AUTOMATIC
RONSPAIN
  • 8 POSTS
The A/C does not blow cold until I rev up to 3,000 RPM or so. Then blows cold...sometimes stops blowing cold...but another rev fixes it up. Any ideas?
Thanks!
Ron
May 6, 2009 at 9:22 AM
FACTORYJACK
  • 4,159 POSTS
Has anything been done to address this yet, have the pressures been read? You need to know that you have a proper charge amount, a properly installed expansion device(orifice tube), and a compressor capable of pumping. Sometimes the orifice tube is in backwards, sometimes it is clogged. Pressure readings can provide some insight. Look for possibly a slipping compressor, too weak electromagnetic clutch and/or excessive air gap between the drive plate and the pulley.
May 6, 2009 at 2:58 PM
