1996 Cadillac Seville Left turn signal
153,000 MILES • V8 • FWD • AUTOMATIC
PB1968
Is there a common poblem with the driver side rear turn signal I replace the bulbs but they don't work. It's almost as if they the lights are dim. What can be done to solve this problem.
Oct 15, 2009 at 12:59 PM
FACTORYJACK
  • 4,159 POSTS
Often times you have one or more sockets that have a poor ground connection, and need replaced with new ones. You can also opt for a complete taillight harness, if it is still available. You can run a ground wire test lead and touch the brass portion of the bulb and sometimes you can see which socket makes a change when grounded.
Oct 15, 2009 at 2:57 PM
