1996 Cadillac Seville leaking coolant
142,000 MILES • V8 • 2WD • AUTOMATIC
YOURHOMEKING
the coolant is leaking out of the car once the car is started
Jun 2, 2009 at 1:59 PM
FACTORYJACK
  • 4,159 POSTS
Where abouts is the coolant leaking. Have the system pressure tested and inspected, it should be easy to locate. There are many possibilities, radiator, hose, coolant pump/housing, etc... A block test for combustion gases in the cooling system would also be recommended.
Jun 2, 2009 at 3:13 PM
