1996 Cadillac Seville Cruse Control & Turn Signal
11,400 MILES • V8 • FWD • AUTOMATIC
RED SIGNAL
My cruse control works sometime but not at all times. The right turn signal does not light all of the rear bulbs yet all of the bulbs are good. Two of the bulbs light when the turn signal is activated but flash at a slow rate compared to the left turn signal. It also, about 30%, does not work.
Apr 13, 2008 at 12:58 PM
BUZZSAW
  • 1,198 POSTS
[quote:2c4ade08d1="Red Signal"]Electrical problem
1996 Cadillac Seville V8 Front Wheel Drive Automatic 114,00 miles
My cruse control works sometime but not at all times. The right turn signal does not light all of the rear bulbs yet all of the bulbs are good. Two of the bulbs light when the turn signal is activated but flash at a slow rate compared to the left turn signal. It also, about 30%, does not work.[/quote:2c4ade08d1]
as far as the turn signals go its either a wrong bulb a bad ground, the cruise is in the sterring wheel right?
Apr 15, 2008 at 6:40 AM
RED SIGNAL
Yes the cruse is located on the steering column
Apr 15, 2008 at 2:58 PM
BUZZSAW
  • 1,198 POSTS
[quote:33deb77264="Red Signal"]Yes the cruse is located on the steering column[/quote:33deb77264]
replace the switch common prob
Apr 15, 2008 at 5:36 PM
