1996 Cadillac Seville Check Brake Fluid Switch
142,350 MILES • V8 • FWD • AUTOMATIC
STEVEG4845
Receiving an intermittent check brake fluid switch message on the DIC. How can I troubleshoot and/or find the switch/sensor to replace etc. Thank you
Jul 13, 2010 at 4:43 AM
FACTORYJACK
  • 4,159 POSTS
The switch is in the master cylinder reservoir. It is a serviceable part. One way to diagnose it, it is normally open and closes with low fluid. If you have a low fluid message, you could disconnect it, and it should go out. You could also check the switch when the message is present, if the switch itself has continuity and the fluid is full, the switch is bad.
Jul 13, 2010 at 3:59 PM
