1996 Cadillac Seville
JESSEBROCKNER
  • 1996 CADILLAC SEVILLE
Engine Mechanical problem
i put the cerpentine belt on and its still loose the reason I replaced it was because I popped my hood and it was loose its on right do any pully move all I see is the tensioner for adjustment
Saturday, July 17th, 2010 AT 11:04 PM
FACTORYJACK
  • 4,159 POSTS
The tensioner is the only one that moves. Is there perhaps a pulley missing? There should be the P.S, tensioner, crankshaft, a/c, an idler, and the alternator. I have seen that idler completely broke off the block. If you have all the pulleys, and nothing is worn or loose, you are either getting the wrong belt for the application, it is routed improperly, or a pulley has been mis-matched somewhere along the line.
Sunday, July 18th, 2010 AT 12:38 PM
