2001 Cadillac Seville removing trannie
TONSKU78
Transmission problem
2001 Cadillac Seville V8 Front Wheel Drive Automatic
Could you please explain step by step what I need to do to get the transmission off from my caddy?
Do I need to drop down the whole craddle or is there some other way too?
It´s giving troublecodes p1860&p0741, so I thought that I go through the whole tranny, the problem is that I´ve never worked with a car that new and FWD!
Sep 15, 2010 at 11:24 AM
WRENCHTECH
  • 20,760 POSTS
Believe me, you have never worked on anything even close to that vehicle. That is one of the hardest systems to work on and I don't suggest to attempt that at all. There are many experienced techs that won't touch that job
Sep 15, 2010 at 11:51 AM
TONSKU78
I decided to do it myself anyways, so could somebody give a hint about it anyways. It may be hard, but I´d like to try it anyway.
I build drag race cars for living, so I can hold the wrench, just wouldnt want to do any extra job. After all those re just bolts and nuts at the end....
PS: sorry for my bad english, here in finland You dont need it that much.
Sep 17, 2010 at 2:07 AM
WRENCHTECH
  • 20,760 POSTS
If you insist on tackling this yourself, then your best bet is to get a service manual or Alldata Online to read up on it. There is just way too much to know to ever post it all here.
Sep 17, 2010 at 2:10 AM
FACTORYJACK
  • 4,159 POSTS
You are going to have to remove the cradle, and hopefully you have a vehicle hoist. An engine support fixture is necessary, at least to support the rear portion of the engine when the trans is removed. Here is the steps from the service manual, it does not include pictures, as there are many. If you are still committed, and need further assistance, reply to post and I will do my best to answer any questions. 12 years with cadillac, and have done a countless number of these procedures.
Transmission Replacement
Tools Required
• J 41623-B Cooler Quick Connect Tool
• J 41160 Transmission Jack Adapter
Removal Procedure
Remove the upper filler panel. Refer to Filler Panel Replacement - Upper in Body Front End.
Remove the upper and lower air cleaner assemblies. Refer to Air Cleaner Assembly Replacement in Engine Controls - 4.6L.
Disconnect the range selector cable terminal from the transaxle range selector lever.
Remove the nuts securing both the range selector cable bracket and heater pipe to the transaxle. Position the range selector cable bracket and heater pipe aside.
Remove the Magnasteer wire from the retaining clip.
Disconnect the master cylinder brake pipe retainers from the side rail.
Important: Supporting the brake pipes above the body side rail is necessary while removing the transaxle in order to prevent pinching of the brake pipes.
Remove the brake pipe retainers from the side rail and using mechanics wire, support the brake pipes above the side rail.
Reposition the main wiring harness to gain access to the upper transaxle to engine bolts (1).
Remove the transaxle to engine bolts (1). The remaining bolt (2) will temporally retain the transaxle and will be removed from the underside of the vehicle.
Place a drain pan under the vehicle.
Remove the upper transaxle oil cooler pipe retaining bolt from the radiator fan shroud.
Disconnect the upper transaxle oil cooler pipe from the radiator using the J 41623-B . Install plugs in the oil cooler pipe and the radiator to prevent fluid loss and contamination.
Disconnect the lower transaxle oil cooler pipe from the transaxle and Install plugs in the oil cooler pipe and the transaxle to prevent fluid loss and contamination. Refer to Cooler Pipe Replacement .
Disconnect the transaxle vent tube from the accelerator bracket.
Install the engine support fixture. Refer to Engine Support Fixture in Engine Mechanical - 4.6L.
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Caution: To avoid any vehicle damage, serious personal injury or death when major components are removed from the vehicle and the vehicle is supported by a hoist, support the vehicle with jack stands at the opposite end from which the components are being removed and strap the vehicle to the hoist.
Secure the vehicle to the front hoist pads.
Remove the stabilizer shaft links. Refer to Stabilizer Shaft Link Replacement in Front Suspension.
Swing the stabilizer shaft downward in order to gain access to the power steering gear retaining bolts.
Remove the left front fascia extension. Refer to Front Bumper Fascia Extension Replacement in Body Front End.
Important: The following are exceptions while following the frame removal procedure:
• Do not remove the front stabilizer shaft from the frame.
• Do not remove the A.I.R pump assembly from the vehicle. Retain the pump to the body using mechanics wire.
• Do not remove the insulators from the frame.
• Do not remove the control arms from the frame.
Remove the front frame. Refer to Front Frame Replacement in Frame and Underbody.
Remove the bolt securing the left transaxle brace to the transaxle.
Loosen the nut securing the left transaxle brace to the engine.
Remove the left transaxle brace from the powertrain assembly.
Remove the 3 ground connections from the side of the transaxle.
Disconnect the transaxle main electrical harness connector.
Remove the bolt (2) securing the front transaxle brace (1) to the transaxle.
Remove the nut securing the secondary AIR pipe to the transaxle.
Remove the nuts (2, 3) securing the vehicle speed sensor heat shield (1) to the transaxle.
Remove the vehicle speed sensor heat shield (1) from the vehicle.
Disconnect the vehicle speed sensor electrical connector.
Remove only the bolts securing the front transaxle brace to the transaxle.
Remove only the bolts securing the center transaxle brace to the transaxle.
Disengage the right and left drive shafts (2) from the transaxle (1). The drive shafts do not have to be removed from the wheels. Refer to Wheel Drive Shaft Replacement in Wheel Drive Shafts.
Using mechanics wire, support the wheel drive shafts out of the way by tying them up to the strut spring.
Remove the torque converter cover. Refer to Torque Converter Cover Replacement .
Important: Mark the flywheel to torque converter position so that they can be assembled in the same position.
Remove the flywheel to torque converter bolts.
Position the power steering gear pressure hose to the right side of the vehicle in order to clear the transaxle during removal.
Support the transaxle using the J 41160 and a suitable transmission jack.
Secure the J 41160 to the transaxle.
Remove the nut (1) securing the left transaxle mount to the left transaxle mount bracket.
Remove the remaining transaxle to engine bolt (2).
Separate the transaxle from the engine.
Tilt the transaxle using the support jack enough to allow clearance for the starter nose cone.
Important: Ensure clearance is maintained between the transaxle and the following:
• The brake pipes
• The secondary AIR pipe
• The power steering pressure hose
• The wiring harnesses
Carefully lower the transaxle from the vehicle.
Flush the transmission oil cooler and pipes. Refer to Transmission Fluid Cooler Flushing and Flow Test .
Remove the transaxle cooler pipe, refer to Cooler Pipe Replacement
Remove the transmission mount bracket mounting bolts (3) and nut (2).
Remove the transmission mount bracket (1).
Remove the transmission mount bracket mounting bolts.
Remove the transmission mount bracket.
Installation Procedure
Notice: Refer to Fastener Notice in the Preface section.
Install the transmission mount bracket and mounting bolts to the engine.
Tighten
Tighten the bolts to 110 N·m (89 lb ft).
Install the transmission mount bracket (1) to the transmission.
Install the transmission mount bracket mounting bolts (3) and nut (2).
Tighten
Tighten the bolts and nut to 50 N·m (37 lb ft).
Install the transaxle cooler pipe, refer to Cooler Pipe Replacement .
• The brake pipes
Carefully raise the transaxle to the engine in a tilted position in order to clear the starter nose cone.
Align the transaxle with the engine and position the transaxle onto the engine dowels.
Install the engine to transaxle bolt (2).
Tighten
Tighten the bolt to 75 N·m (55 Ib ft).
Connect the vehicle speed sensor electrical connector.
Install the engine to transaxle center brace and heat shield. Refer to Transmission Brace Replacement .
Install the bolts securing the front transaxle brace to the transaxle.
Tighten
Tighten the bolts to 50 N·m (37 Ib ft).
Raise the transaxle and install the nut (1) securing the transaxle mount to the transaxle mount bracket.
Tighten
Tighten the nut to 75 N·m (55 Ib ft).
Remove the transmission jack and the J 41160 .
Important: Line up the flywheel and converter using the alignment marks made during disassembly.
Install the flywheel to converter bolts.
Tighten
Tighten the bolts to 60 N·m (44 Ib ft).
Install the torque converter cover assembly. Refer to Torque Converter Cover Replacement .
Install the engine to transaxle bracket lower bolt (1).
Tighten
Tighten the bolt to 50 N·m (37 Ib ft).
Install the right and left drive shafts (2) to the transaxle (1). Refer to Wheel Drive Shaft Replacement in Wheel Drive Shafts.
Install the 3 ground connections to the side of the transaxle.
Tighten
Connect the transaxle main electrical harness connector.
Install the left transaxle brace to the powertrain assembly.
Install the bolt securing the left transaxle brace to the transaxle.
Tighten
Tighten the left transaxle brace bolt to 50 N·m (37 Ib ft).
Tighten
Tighten the left transaxle brace nut to 41 N·m (30 Ib ft).
Install the front frame assembly to the vehicle. Refer to Front Frame Replacement in Frame and Underbody.
Install the left front fascia extension. Refer to Front Bumper Fascia Extension Replacement in Body Front End.
Install the stabilizer shaft links. Refer to Stabilizer Shaft Link Replacement in Front Suspension.
Lower the vehicle.
Connect the lower transaxle oil cooler pipe to the transaxle. Refer to Cooler Pipe Replacement .
Install the upper transaxle oil cooler pipe to the radiator. Refer to Cooler Pipe Replacement .
Install the remaining transaxle to engine bolts (1).
Tighten
Tighten the bolts to 75 N·m (55 Ib ft).
Remove the engine support fixture. Refer to Engine Support Fixture in Engine Mechanical - 4.6L.
Install the range selector cable bracket to the studs on the transaxle.
Install the heater pipe to the stud on the transaxle.
Install the nuts that retain the heater pipe and the range selector cable bracket to the transaxle.
Tighten
Tighten the nuts to 25 N·m (18 Ib ft).
Connect the range selector cable terminal to the transaxle range selector lever.
Install the Magnasteer wire to the retaining clip.
Connect the transaxle vent tube to the accelerator bracket.
Install the brake pipe retainers to the side rail.
Install the upper and lower air cleaner assemblies. Refer to Air Cleaner Assembly Replacement in Engine Controls - 4.6L.
Install the upper filler panel (1). Refer to Filler Panel Replacement - Upper in Body Front End.
Add DEXRON® VI transmission fluid as required. Refer to Fluid Capacity Specifications and Transmission Fluid Check .
Important: It is recommended that transmission adaptive pressure (TAP) information be reset.
Resetting the TAP values using a scan tool will erase all learned values in all cells. As a result, The ECM, PCM or TCM will need to relearn TAP values. Transmission performance may be affected as new TAP values are learned.
Reset the TAP values. Refer to Adapt Function .
Measure the wheel alignment. Refer to Wheel Alignment Measurement in Wheel Alignment.
Road test the vehicle and check for transaxle leaks.
Sep 27, 2010 at 4:03 PM
