Starts, warms up and idles fine. Good gas mileage and performance. No hesitation.
After listening to different components with a wooden dowel, the only noise comes from the forward valve train but only under light loads in the lower RPM range. I get it while cruising constant speeds, with or without cruise control. The sound is reproduce-able while applying a gentle power brake. No codes. EGR valve and solenoid seem to function fine. Removed valve cover to inspect. Nothing out of place or loose.
Being a new owner, I was caught by surprise with a low oil level at about 50% oil life. It had 10-30 synthetic. I added a quart+ and that's when the noise began. Very slight at first then after about 800 miles, it's kinda loud. Changed oil to a higher viscosity 15-40. No change.
Oct 19, 2010 at 11:45 AM
