Emergency Brake Release
1995 CADILLAC SEVILLE
BILLBURNOPP
Brakes problem V8 Front Wheel Drive Automatic 140000 miles
The emergency brake will not release when put in drive. How do I fix this?
Feb 4, 2010 at 7:40 AM
FACTORYJACK
  • 4,159 POSTS
On a 95 there is a vacuum actuator that releases it. check that a vacuum signal is getting there when running and shifted to rev/drive. Replace the vacuum actuator if a signal is present. There is a manual release for it, down on the pedal assembly. There is a switch that will release the parking brake check out the diagrams below.
Feb 4, 2010 at 10:10 AM
BILLBURNOPP
Ah! the vacuum line fall off thanks for the tip and guide.
Feb 14, 2010 at 10:00 AM
