1994 Cadillac Seville SLS, Northstar engine 95,000 miles
PMALONE
  • 1994 CADILLAC SEVILLE
I just had my water pump relaced but my car is still over heating. I was told to make sure that it was bleed and if that doesn't work it is more than likely a blown head gasket. My mechanic told me that my car does not have to be bleed after replacing water pump, is that true? I have a Northstar engine. If it does need to be bleed, how do you do that?
Wednesday, April 18th, 2007 AT 8:55 PM
LADYDIMEND
Have you gotten any answers to your over heating problem? Mine over heats as well. I haven't gotten mine fixed yet but was told that it is possible a PLASTIC INTAKE by the manifold. Please advise if you have had your car fixed and if this was the problem.
Thursday, October 25th, 2007 AT 4:44 PM
BUZZSAW
  • 1,198 POSTS
No it doesnt need to be bleeded. Are you still loosing coolant? How bad did you overheat it? Did he put a t-stat in also?
Monday, October 29th, 2007 AT 11:23 AM
