1994 Cadillac Seville Rear suspension
190,000 MILES • V8 • FWD • AUTOMATIC
QUIGLYUPOVER
The auto ride suspension is stuck in the "up" position. I had some weight in the trunk and the system adjusted. When I took the weight out, the suspension stayed in the heavy position and the back end of the car is now raised up. When I go over a bump, the rear end bounces a lot. I am getting a warning message that says "service auto ride suspension". Any ideas???
Jun 1, 2008 at 11:51 AM
BUZZSAW
  • 1,198 POSTS
[quote:0713d3d1dc="quiglyupover"]Suspension problem
1994 Cadillac Seville V8 Front Wheel Drive Automatic 190000 miles
The auto ride suspension is stuck in the "up" position. I had some weight in the trunk and the system adjusted. When I took the weight out, the suspension stayed in the heavy position and the back end of the car is now raised up. When I go over a bump, the rear end bounces a lot. I am getting a warning message that says "service auto ride suspension". Any ideas???[/quote:0713d3d1dc]
scan your codes, off and warmer on the heater controls at the same time, with your key in the on position
Jun 8, 2008 at 9:11 PM
