1994 Cadillac Seville no gas
115,000 MILES • V8 • FWD • AUTOMATIC
ACOUSTIFUN
My car has been out of comission for about a year, first off. So we've changed out fluids, new battery, new fuel filter because the vehicle was not getting gas to the plugs. I'm wondering if the problem is my fuel pressure regualtor or if the problem is more likely to be the fuel injectors
Jan 2, 2008 at 11:28 AM
  • 31,937 POSTS
If the car has been sitting for some time, the fuel pump may be stuck, first check for power at relay, (located on relay block near washer bottle) if power is ok, Check for pump operation (fuel pump is an in tank pump) often pumps will lock up if left dry foe any length of time.
Mark (mhpautos)
Jan 2, 2008 at 7:07 PM
