1994 Cadillac Seville Brake Pedal Goes to the floor
200,000 MILES • V8 • FWD • AUTOMATIC
BILLCADDY
The brake pedal of our 94 Cadillac Seville STS goes to the floor with the engine running. I have replaced the master cylinder and have not noticed any leaks at the brake cylinders. If i pump the brakes, it will build up pressure, or if i am sitting still and i spin the tires (it is winter here now) and i and hit the brakes right after, it works fine. I am wondering if there may be a problem with the vacuum booster, or ABS componants? Other than bleeding the brake lines again, I can't think of anything else.
Dec 29, 2009 at 10:09 AM
FACTORYJACK
  • 4,159 POSTS
It sounds like you just have air in the system. The reason it seems to work after spinning, is probably because of the ABS.
Jan 1, 2010 at 4:36 AM
