1992 Cadillac Seville No hot air comes from heater
1992 CADILLAC SEVILLE
162,000 MILES • V8 • 2WD • AUTOMATIC
NNARISI
  • 8 POSTS
My 1992 seville does not blow hot heat. The blower is brand new. I've flushed the coolant system and checked the heater core and coolant is flowing fine through it. Is there a value that allows the hot air to be blown to the vents.
Nov 3, 2010 at 8:32 AM
Test the thermostat if okay-Check the air blend door if its stuck in the cold position and heater control valve
Nov 3, 2010 at 9:21 AM
NNARISI
  • 8 POSTS
Thermostat is good. Is the air blend door behind the glove box? How about the heater core valve?
Nov 4, 2010 at 4:21 AM
