Engine Cooling problem
1992 Cadillac Seville V8 Two Wheel Drive Automatic
radiator, thermostat, water pump have been replaced and it still overheats - what else could be wrong?
Sunday, August 16th, 2009 AT 10:01 PM
DOCFIXIT
MECHANIC
Have you checked the cooling fan is it comming on?
SPONSORED LINKS
Monday, August 17th, 2009 AT 10:17 AM
BANDIT007
MEMBER
I havent even seen the car yet - it is for sale for $500.00. Would there be a bad sensor causing it to not cool down? I will be looking at it tonight. Start the car and let it run a while and see if the cooling fan does come on.
Monday, August 17th, 2009 AT 10:27 AM
RONALDLMCKEE
MEMBER
This car may have a blown head casket or crack in the head. If so, it will be losing water as an added symptom. These are very expensive to fix and may not be worth the cost.
