1992 Cadillac Seville COOLING FAN
160,000 MILES • V8 • FWD • AUTOMATIC
LITESKINDJ
MY FAN THAT BLOWS ON THE RADIATOR DOESN'T COME ON AT ALL. I CHECK THE FUSE AND ALSO SLIT THE WIRES AND RAN WIRES TO THE FAN STRAGHT TO THE BATTERY TO SEE IF IT WOULD COME ON AND THAT DIDNT WORK EITHER. WHAT ELSE COULD BE WRONG?
Apr 16, 2010 at 6:11 AM
  • 75,988 POSTS
If you're directing battery power to it and won't come on-its defective- did you wire it correctly.
Apr 16, 2010 at 7:03 AM
LITESKINDJ
YES I DID WIRE IT CORRECTLY, SO YOU THINK ITS THE FAN ITS SELF? THERE'S NO OTHER PLACE FOR FUSES BUT THE FRONT OF THE ENGINE AND IN THE TRUNK CORRECT?
Apr 16, 2010 at 7:40 AM
  • 75,988 POSTS
Sounds like the fan motor even if its hooked-up incorrectly it should come on forward or reverse mode.
Apr 16, 2010 at 8:02 AM
LITESKINDJ
WILL A ELECTRIC FAN BE ABLE TO REPLACE THE ORIGINAL FAN ITS SELF?
Apr 17, 2010 at 12:26 AM
