1988 Cadillac Seville Reply to buzzsaw
200,000 MILES • V8 • FWD • AUTOMATIC
CPOWDER
  • 16 POSTS
I dont have any security lights coming on or flashing across the screen or nothing,it just do it when it feels likeit,Like I mentioned earlier that I had a short in my ignition Fixed in2005 an I didn't really get the chance to drive it much cause up here in Michigan if you've had a car painted its best not to drive in the snow&salt,but I just use to start it up an let it idle,But now its like as soon as I cut the car off an try to restart it the car won't make a sound all the dash lights come on but no starter sound an thats new(starter)! But whats crazy is that all the wireing under the dash is all on the same harness including all the ABS wireing I jus found out that the Wireing to the ABS motor has a short in it an the ignition is all on the same wireing harness !!!!This makes you wanna pull you hair out I sewer!!!
Apr 10, 2008 at 3:56 AM
BLACKOP555
  • 10,386 POSTS
please find your original topic, and reply to that to keep the information in one topic and so buzzsaw can continue with you.
Apr 10, 2008 at 7:55 AM
BUZZSAW
  • 1,198 POSTS
[quote:0663c1be40="cpowder"]Electrical problem
1988 Cadillac Seville V8 Front Wheel Drive Automatic 200000 miles
I dont have any security lights coming on or flashing across the screen or nothing,it just do it when it feels likeit,Like I mentioned earlier that I had a short in my ignition Fixed in2005 an I didn't really get the chance to drive it much cause up here in Michigan if you've had a car painted its best not to drive in the snow&salt,but I just use to start it up an let it idle,But now its like as soon as I cut the car off an try to restart it the car won't make a sound all the dash lights come on but no starter sound an thats new(starter)! But whats crazy is that all the wireing under the dash is all on the same harness including all the ABS wireing I jus found out that the Wireing to the ABS motor has a short in it an the ignition is all on the same wireing harness !!!!This makes you wanna pull you hair out I sewer!!![/quote:0663c1be40]
think that does that to you, Pulling hair out and swearing, the more you know how things work the easyer it gets tho. lol try being a mechanic dealing with this every day lol, well once you turn it off you need to ck the purple wire to the starter, it comes from the Ign switch for power, use a test light, have some one turn the key and you watch the test light, if it lights that means power is comming through your ign switch and the starter is the problem, new or not. if you dont have power there then its your Ign switch or security sys
try that and let me know, thanks
Apr 10, 2008 at 11:07 PM
CPOWDER
  • 16 POSTS
[quote:fafa443af9="blackop555"]please find your original topic, and reply to that to keep the information in one topic and so buzzsaw can continue with you.[/quote:fafa443af9] Every time I try to reply to the point system on the site keeps telling me I don't have enough points or that zero is not enough.So I'm haveing replying problems but thanks for the advice
Apr 11, 2008 at 3:10 AM
CPOWDER
  • 16 POSTS
[quote="blackop555"]please find your original topic, and reply to that to keep the information in one topi
Every time I try to reply the point system gets in the way by telling me thatr I dont have enough points
Apr 11, 2008 at 3:14 AM
BUZZSAW
  • 1,198 POSTS
[quote="cpowder"][quote:3166213381="blackop555"]please find your original topic, and reply to that to keep the information in one topi
Every time I try to reply the point system gets in the way by telling me thatr I dont have enough points[/quote:3166213381]
to reply hit quote
Apr 11, 2008 at 10:39 AM
