I dont have any security lights coming on or flashing across the screen or nothing,it just do it when it feels likeit,Like I mentioned earlier that I had a short in my ignition Fixed in2005 an I didn't really get the chance to drive it much cause up here in Michigan if you've had a car painted its best not to drive in the snow&salt,but I just use to start it up an let it idle,But now its like as soon as I cut the car off an try to restart it the car won't make a sound all the dash lights come on but no starter sound an thats new(starter)! But whats crazy is that all the wireing under the dash is all on the same harness including all the ABS wireing I jus found out that the Wireing to the ABS motor has a short in it an the ignition is all on the same wireing harness !!!!This makes you wanna pull you hair out I sewer!!!
Apr 10, 2008 at 3:56 AM
