1981 Cadillac Seville Code 25
75,000 MILES • V8 • 2WD • AUTOMATIC
FINAJET99
Hi, (modulated displacement failure)... is this something that I can replace, repair... somewhat handy at things like this, or do I need to take it in.... or what other suggestions might there be...
any info is greatly appreciated...
Aug 4, 2008 at 12:34 PM
2CARPRO JACK
  • 11,533 POSTS
Is that a 4,6,8? IE: variable displacement? If so Im amazed it took it this long to fail. There is a big connector on the transmission, try unplugging it, this makes it a V8 all the time, the only fix for that I have ever heard of, wrong execution of the right idea
Aug 6, 2008 at 12:42 AM
FINAJET99
Thanks.... yes it is that engine.. I disconnected the connections on the valve covers.... will that work just as well.... do not need the cruise control if that is an issue...
Thanks
Aug 10, 2008 at 6:41 AM
2CARPRO JACK
  • 11,533 POSTS
No problem
Aug 11, 2008 at 12:37 AM
