1976 Cadillac Seville Loosing transmission fluid
1976 CADILLAC SEVILLE
54,000 MILES • V8 • 2WD • AUTOMATIC
BRUGLEY76
I'm using 2 qtrs of transmission fluid every 3 days or so but there isn't any sign of it leaking out. My car smoke when I start it after it has been sitting and the smoke is not a steady stream of steam like a blown head gasket.
Oct 20, 2009 at 1:30 PM
DOCFIXIT
  • 18,828 POSTS
Shift modulator diaphram torn sucking fluid into intake. Jack up on pass side rear of trans see small can with line attached? remove if fluid present replace.
Oct 21, 2009 at 3:36 AM
