1976 Cadillac Seville Engine Fuel Injection
90,000 MILES • V8 • 2WD • AUTOMATIC
RICK.33
This is a 76 model SvilleCad with fuel injection I have replaced module above brake booster @ firewall, also replaced distributor,TPS checked entire vacum system. I drained gas tank and replaced fuel pump Also replaced fuel filter at fuel pump at rear axle and checked that fuel pump. Yes this vehicle has 2 fuel pumps. I checked fuel pressure @ fuel rail What I have determined is the fuel injectors are not getting a signal to inject I can pour a small amount of gas into the throttle body and it will run for a few seconds. any specs.or Advice info. would be greatly appreciated.
Apr 28, 2010 at 4:44 AM
MERLIN2021
  • 17,250 POSTS
Check your email, I sent info on the system, and testing info...
Apr 28, 2010 at 7:22 AM
