1998 Other Cadillac Models replacement pully
1998 CADILLAC
135,000 MILES • V8 • 2WD • AUTOMATIC
VALERIEME
How do you remove the air conditioning compresser so I can put a replacement pully on it is there anything tricky I should knowabout?
Sep 27, 2010 at 9:19 AM
WRENCHTECH
  • 20,760 POSTS
That's not something I recommend you trying. Not only do you need specialty tools and equipment but 95% of the time when something happens to that clutch, the rest of the compressor has or will have issues too and then you just wasted everything you did because the replacement compressor already comes with a clutch.
Sep 27, 2010 at 10:15 AM
