Will not start when engine is warm
1995 CADILLAC
13,500 MILES • V8 • FWD • AUTOMATIC
CADDYDOG
In the morning the car will start. After I drive the car for about ten to fifteen miles and turn the car off, return after ten minutes the car will not start unless I put gas in the throttle body. Even then I have to put the gas pedal all the way down and rev the engine until the engine smooths out. If the car cools down totally, then it will start, but if it is hot and I turn the car off for only five minutes it will not start.
Nov 14, 2009 at 11:51 AM
HMAC300
  • 48,601 POSTS
Thank you for visiting 2CarPros.com. I would check to see if the fuel filter is plugged or low fuel pressure. Here is a guide from our site on checking fuel pressure:
If you need further assistance please come back to the site we are always happy to help.
Jan 14, 2010 at 12:00 PM
FRANK THE TANK63
Hey Caddydog, I have the exact same problem! Did you have any luck fixing it? What was the problem/fix?
Thanks!
May 29, 2018 at 8:48 AM
  • 55,682 POSTS
We have seen this problem before and replacing the fuel pump fixes it. Here is a guide to help you see what you are in for when doing the job a diagrams to help you see what it will be like on your car. You can get the pump from Amazon.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Cheers, Ken
May 29, 2018 at 9:44 AM
