1992 Other Cadillac Models Brake Rotors
1992 CADILLAC
100,000 MILES • V8 • 2WD • AUTOMATIC
BIGDADDYCADDY
I have a 1992 Cadillac Fleetwood Brougham, the front brake rotors are totally shot and I dont have the money to buy new ones right now.
But i also own a 1988 Fleetwood Brougham, same body style, both RWD, both 5.0L V8. The front rotors on the 88 are pretty much brand new, I was wondering if they would fit / work on the 92.
I know the only differnce is the ABS but im not sure if either car has it. Or what the differnce is in the rotors.
I plan on buying new parts when I have the money, but till then I need a car to drive, and you cant drive it the way it is.[img:f04d5ed0c2]http://www.2carpros.com/forum/automotive_pictures/534965_218678c_20b_1.jpg[/img:f04d5ed0c2]
Jun 4, 2010 at 6:29 AM
FACTORYJACK
  • 4,159 POSTS
The specifications I have are limited to thickness, and it is the same for 88 and 92 Brougham. 1.031" nominal thickness, .972" minimum discard thickness. If either one has ABS, it will have a tone ring(reluctor) pressed onto the inside. There are other possibilities that could create incompatibility, total rotor diameter which you can measure, and the bearings used.
Jun 4, 2010 at 3:14 PM
