1989 Other Cadillac Models altanator or battery
1989 CADILLAC
230,000 MILES • V8 • FWD • AUTOMATIC
FIVE_EFS
i bought a new battery and an altanator and replaced them and they do not work proporly the battery dies and the altanator acts like it is not working but everything is installed properly.
Jan 13, 2008 at 10:39 AM
BUZZSAW
  • 1,198 POSTS
[quote:37eb2cb380="five_Efs@hotmail.com"]Other Category problem
1989 Other Cadillac Models V8 Front Wheel Drive Automatic 230000 miles
i bought a new battery and an altanator and replaced them and they do not work proporly the battery dies and the altanator acts like it is not working but everything is installed properly.[/quote:37eb2cb380]
where did you buy the parts?
Jan 14, 2008 at 8:22 AM
FIVE_EFS
I had purchased my parts at A-1 auto parts the battery worked just fine untill it died we had the altanator tested and it checked out ok. do you know of any reason why it would not charge the battery??
Jan 15, 2008 at 3:42 AM
BUZZSAW
  • 1,198 POSTS
[quote:e273f5d132="five_Efs@hotmail.com"]I had purchased my parts at A-1 auto parts the battery worked just fine untill it died we had the altanator tested and it checked out ok. do you know of any reason why it would not charge the battery??[/quote:e273f5d132]
charge the battery up and ck it for a draw, after charged remove the neg battery cable and hook up an amp meter, between the battery and the cable, let it sit there for about 10 to 15 min, then look at it, should be below .30 of an amp, anything higher will run down the battery, if its higher you will have to start pulling fuses til it goes away and then find a wiring scematic of that fuse
Jan 15, 2008 at 6:37 AM
FIVE_EFS
thanks for the info i will try that and let you know how it works
Jan 16, 2008 at 3:11 AM
