Cadillac Northstar normal operating temp discrepancy
170,000 MILES • 4.6L • V8 • FWD • AUTOMATIC
IMAQUESTIONMAN
Under normal driving conditions my 97 Cadillac Deville's coolant temp runs at about 190-192F. Experts say that that 190 up to 205 is a normal operating temp. If that is a normal operating temp for the engine then why is it set so that the high speed fan doesn't come on till the coolant temp hits 234 and rising? The the most catastrophic thing that can happen to an engine is for it to over heat. Why wait till just before overheating to turn the fan on? Why tempt fate? If it's good for it to run in the 230's then why does it normally run at 190 to 205? Splain Lucy.
Mar 24, 2016 at 8:15 AM
HMAC300
  • 48,601 POSTS
if it gets to 230 degrees under certain circumstances is no big deal when fan kicks on . coolant is under pressure so it takes a bit more before it overheats.and when it hits that temp to kick on fan it usually brings it down to normal range.
Nov 26, 2019 at 10:44 AM
