When accelerating the car has started to fade then when you let up off of the accelerator it will run but as you accelerate again it dies, it backfired several times, and also died in drive, I put it in neutral and it starts right up, it might go for 10 - 15 miles and then the fade starts again or the engine dieing out while in drive.
I am assuming it might be the plugs, plug wires, ,maybe it needs a tune up or a distributor cap or all of these, am I close?
Aug 24, 2014 at 7:38 AM
