1989 Cadillac Hearse map sensor
72,000 MILES • V8 • AWD • AUTOMATIC
CAROLRAE
we did a tune up on my caddy and immediately check engine came on...we had it tested. said map sensor went out. after 3 weeks to find RIGHT ONE and had to redo map sensor AND redo new harness. the light STILL comes on. we undid the battery for a half hour and put it back together and lite STILL comes on and runs worse than ever. idol off or timming....any suggestions??? i need help
Aug 19, 2010 at 12:21 AM
WRENCHTECH
  • 20,758 POSTS
Do you have a good vacuum supply connected to it?
Aug 19, 2010 at 12:31 AM
CAROLRAE
do you mean from the little hose that gets connected to the mapsensor itself underneath??? i havent tried it. do i try it with car running??? im a female and ive been workin right along the man workin on my tuneup. so i do know the hose you might be talkin about. how can i tell.?? put paper to it and see if it sucks to it>????
Aug 19, 2010 at 12:37 AM
WRENCHTECH
  • 20,758 POSTS
That's what a MAP sensor does. It measures he engine vacuum so it has to have a good sealed line to the vacuum supply. You should be using a vacuum gauge to measure it. If that's not the problem, then your going to need a scan tool to read the sensor data in the ECM. You could have a wiring problem.
Aug 19, 2010 at 12:55 AM
CAROLRAE
thanx for advice....immediatly after a tune up the map sensor gave problems...we replaced original one with a whole new senor type and harness cus the 1989 piece was obsolete. so they say cuis it took 3 weeks of searching for part!..we will heck the vacume and wires to night. THANK YOU! so much for helpin us out here.... hugs
Aug 19, 2010 at 1:11 AM
CFERRY1
  • 29 POSTS
Dear carolrae -
It is possible that my 1990 Cadillac is similar to your 1990 Cadillac Hearst. I am sure these vehicles are becoming somewhat obsolete. I would be interested in talking with you about your vehicle. I may be contacted at email "ferrycha@hotmail.com"
Thank You
cferry1
Jan 20, 2012 at 12:46 AM
