1996 Cadillac Fleetwood doesn't produce much cool air
1996 CADILLAC FLEETWOOD
62,000 MILES • V8 • AWD • AUTOMATIC
CRUSIN4U
AC makes noise, doesn't produce enough cool air to
effectly make a difference
Jul 20, 2009 at 4:37 AM
LEGITIMATE007
  • 5,121 POSTS
if what your saying is the volume of air that comes through the vents, is cold, but not enough to cool the inside of the car off, then that means the evap core is mostlikely clogged with dust and debris and will need to be cleaned off, you will get a build up over the years and it will drastically reduce the air volume coming from the vents.
Jul 20, 2009 at 5:09 AM
