1994 Cadillac Fleetwood
BABY_DREX
Air Conditioning problem
1994 Cadillac Fleetwood V8 All Wheel Drive Automatic
Today when i turned my car off the a/c seemed to keep running and the air that was blowing was making the window fog up, and there is no way for me to turn it off without removing the fuse
Aug 11, 2009 at 1:38 PM
CAR WIZARD
  • 11 POSTS
if your blower motor continues to run after key is removed your blower motor regulator has shorted.
fog on your windsheid may be a resticted evaporator drain or maybe normal if its real humid out.good luck.
Aug 11, 2009 at 1:43 PM
BABY_DREX
my blower motor regulator do you think that a part i can buy and repair my self
Aug 11, 2009 at 1:57 PM
CAR WIZARD
  • 11 POSTS
its not a bad job.the regulator is the part that has the wiring that goes to the blower motor and another wire set plugged in to it.
Aug 12, 2009 at 10:01 AM
