1993 Cadillac Fleetwood oil
1993 CADILLAC FLEETWOOD
184,766 MILES • V8 • 2WD • AUTOMATIC
HSEMAN
leaking oil near the oil pan,but i can't find a leak
Aug 12, 2008 at 3:02 AM
JOE LORENTI
  • 6 POSTS
You may want to check your valve cover gasket. When they leak they have a tendancy to drip oil down the side of the motor block, which can appear to be coming from the oil pan. If you are sure that it's an oil leak, then you may first want to steam clean the area that is drenched with oil so that you may have a better chance of finding it. Good luck!
Aug 21, 2008 at 3:06 PM
