1993 Cadillac Fleetwood engine won't crank
YOUNGLR
Other Category problem
1993 Cadillac Fleetwood Engine Size unknown Wheel Drive Type unknown Automatic 10000 miles
replaced battery and fuel pump
if it cranks, and runs a short while, it will still crank, but won't turn over. What to check next?
Jan 27, 2008 at 7:18 AM
BUZZSAW
  • 1,198 POSTS
[quote:839fd2fa6e="younglr"]Other Category problem
if it cranks, and runs a short while, it will still crank, but won't turn over. What to check next?[/quote:839fd2fa6e]
cranking and turning over is the same thing, turn the key and a click means the starter solinoid is clicking, scan the codes, off and warmer on the heater controls with key in the on posision, codes will be in the heater face plate. Do you also have anything comming across the IP like wait 3 minutes til starting?
I need the codes!!!
Jan 28, 2008 at 3:30 AM
