1990 Cadillac Fleetwood Replacing Engine
1990 CADILLAC FLEETWOOD
114,000 MILES • V8 • 2WD • AUTOMATIC
GREGORYKIPPER
Can I replace a 1990 Cadillac 5.0L-307 CID-Oldsmobile engine (if that is what it is) with a 1968-1980 350, 2 or 4 Main Cap Bolt, Small Block Chevy Engine? Casting # 3970010
Feb 22, 2008 at 7:04 AM
BUZZSAW
  • 1,198 POSTS
[quote:e71657f27c="gregorykipper"]Engine Mechanical problem
1990 Cadillac Fleetwood V8 Two Wheel Drive Automatic 114000 miles
Can I replace a 1990 Cadillac 5.0L-307 CID-Oldsmobile engine (if that is what it is) with a 1968-1980 350, 2 or 4 Main Cap Bolt, Small Block Chevy Engine? Casting # 3970010[/quote:e71657f27c]
a small block chevy is the same, use some old parts, block and heads will be different
Feb 24, 2008 at 6:46 PM
