1990 Cadillac Fleetwood Cadillac died while running, now wi
170,000 MILES • V8 • FWD • AUTOMATIC
PMIZZI
Changed Ignition module, changed plugs plus wires, changed rotor, changed distributor cap, new battery, new alternator, new belt; still no spark.
Changed gas tank and fuel pump last year. Could it be either the ignition switch in the sterring colum or feul sending unit? Unless you suggest somthing else. I am at the point of giving up and sending this no rust immaculate looking car to the dump.
Your help is greatly appreaciated.
Aug 30, 2009 at 1:31 PM
  • 75,988 POSTS
Test the coil's primary and secondary windings resistances and the distributor pick-up coil. Make sure the coil is getting battery voltage
Aug 30, 2009 at 5:11 PM
PMIZZI
Thanks for the advice. We will give that a try and see if it works.
That worked. The coils were the problem. Now all is in place and the car is running.
Aug 31, 2009 at 3:15 AM
